- Joined
- 6 Sep 2004
- Messages
- 1,069
- Reaction score
- 71
- Country
I require to drill into a ceramic tile (200 x 200mm) which is fixed to a stud partition wall to secure a wall plate for a shower bar. The supply holes need to be 25mm diameter, 150mm apart. I am planning to use a similar drill bit to this and this jig. The reason I am a bit a little apprehensive of this task is that tiles I have drilled previously have been of a slightly larger diameter (30- 35mm) and there was an arbour drill as part of the kit. I don’t think arber drills come with holecutters less than 30mm but I may be wrong here. Are there any precautions/advice to be considered here? Would it be wise to create a plywood guide of some sort?
Thanks for any help offered.
