Hi there -
I live in a ground floor maisonette built in the 1960s. Above our upper floor is the lower floor of another maisonette.
There is a thick (8 inches or so) concrete plinth that forms the ceiling of our upper floor and the floor of the maisonette above.
I need to install a curtain rail in one of our bedrooms, but have to use a ceiling / top fix due to the nature of the windows we have. This means I need to drill into the concrete to fix the rail.
Unfortunately, I can not seem to drill into the concrete! I have a 500W corded power drill and need to drill a 6mm hole about 25mm deep into the ceiling. The plaster drills easily enough, but when the masonry drill bit hits the concrete I hardly get any progress into the material. When I've really tried to push hard, the bit has ended up slipping in the chuck.
Please can someone advise what I can do in this case? Ideally I want to drill the concrete - is it just that I have cheap masonry drill bits (which I do - I've tried the 3mm bit with no luck either)? If I can't drill the concrete, can anyone suggest an alternative approach?
Many thanks for your help,
John.
John.
