Hi
Hope someone can help. Our downstairs toilet still fills (via drips) even when the float valve is up. So eventually it reaches the overflow. Also occasionally the screw holding the float in place comes out and it fills even more quickly until I can push it back in. It is a bottom-filling cistern. Just behind where the blue valve drips from, there is what looks a bit like a connection, but I'm not sure. My question is can you replace just the blue valve , or that section and the float valve presumably, or do you have to replace the whole section from the base of the cistern up? If so, how easy is that to do (I'm thinking about the seal at the bottom). Also, when it does overflow, we get water down the side of the overflow pipe onto the floor which suggests a bad connection at the base. Is that easily fixed? Thanks
