The Mira 88 installed some 30 years ago is dripping hot water from the rose. Mira are pretty good with spares
So to take it apart I have to shut off the supply.
IE the cold inlet (no problem) and the cold supply to the hot water cylinder.
The AGA supplies hot water to the cylinder as well as the immersion heater (when turned on).
There are two (inlet) pipes on opposite sides at the bottom of the water cyl, one from the cold tank in the loft, this has a valve that I can turn 1/2 a turn but only after using a wrench to turn the black hand wheel. It is also starting to weep at the top or end of the valve that the wheel goes onto after my efforts.
The other pipe I assume is a feed from the AGA, I have found a valve for this.
It is a high scale area, Limestone so hard they stopped quarrying it 80 years ago.
So what's the plan Sam?
Do I continue trying to ease the valve?
