I would expect the White wheel to pull off the splines in the absence of seeing a screw or circlip in the photo and this will probably reveal the cartridge to be unscrewed from the tap body.
Have you got the White wheel off yet and removed the cartridge? Then you have to match it from several on the market unless you know the manufacture, fine for you but for the plumber time is money I`m afraid.
Ain’t planning on using a plumber as I thought this would be simple. Cannot see how to remove the white wheel so guess I need to look at other options.
