Dripping noise from combi boiler
16 Feb 2020
My mums Worcester Bosch boiler makes intermittent drip like noises and am having to re pressure it almost every day. Council serviced it in Feb and engineer said possible leak under floor but said boiler still aokay. I dont mind the re pressuring its the drip noise thats got me spooked. Is this situation dangerous?
If you have to re pressure almost every day ,water is leaking out ,either from the boiler or the system. You need an engineer to visit.
Do you think it could wait until this 3 month lockdown situation has passed?
As above denso13 + terryplumb above get Council back ASAP given the imminent [possible] lock down that [may] be coming
Question 1 ? does your Mum own or rent?
Question 2 ? do you know if the ground floor is a concrete slab with timber battens then the flooring??
Ken
Ken GMac. She rents its sheltered bungalow. At moment she is so freaked out about being in isolation (albeit I am there everyday cos shes 99) that some engineer turning off heating and ripping up floor might be too hard to bear. Ive no idea whats beneath her laminate but I dont think its concrete and no sign of any water damage in cupboard or anywhere else
