Surface tension? Crazy man say what?joe-90 said:Is the water level adusted properly? Surface tension will keep the thing dripping if the level is set too high.
Softus said:Surface tension? Crazy man say what?joe-90 said:Is the water level adusted properly? Surface tension will keep the thing dripping if the level is set too high.
Of water? At 20°C it's 0.0726 N/m.joe-90 said:Do you know what surface tension is?
Softus said:Of water? At 20°C it's 0.0726 N/m.joe-90 said:Do you know what surface tension is?
I know lots of things, the existence of most of which you're not even aware, but nothing within my sphere of experience or knowledge explains why you've associated surface tension with this topic, hence my assertion that you're crazy. You crazy bloke. Tch.joe-90 said:There you go then...
Softus said:I know lots of things, the existence of most of which you're not even aware, but nothing within my sphere of experience or knowledge explains why you've associated surface tension with this topic, hence my assertion that you're crazy. You crazy bloke. Tch.joe-90 said:There you go then...
Meniscus...or MencapSoftus said:Surface tension? Crazy man say what?joe-90 said:Is the water level adusted properly? Surface tension will keep the thing dripping if the level is set too high.
Softus said:ChrisR has the problem in hand, and nothing more can be offered until the OP replies. However, your offering is not only wrong, but bizarrely so, and I'm helping "the guy" by making that clear to him/her.
Regarding the alleged search for trouble, wherever your posts appear no looking is necessary.
BTW, surface tension is a property of all fluids, albeit to differing degrees, not just water.
This is something I haven't heard of. Is the see-saw bright blue with horsey heads on?joe-90 said:If the ballcock is set too high you will get hydraulic see-sawing which often fools the poster because it overflows for a while - and then stops, then overflows - and then stops.
Something of a fatuous remark, since you know perfectly well that I know some things about some things.joe-90 said:If you knew anything about anything you would realise that.
I quoted you a figure for the force of surface tension of water, in air, at 20°C, so it seems odd for you to suggest that I'm excluding water from the set of known fluids. Unless...can it be?! Is it that you actually know very little about the subject? Shirley not?!joe-90 said:After all, as you say, all fluids have differing surface tension - so that MUST include water eh?
Softus said:This is something I haven't heard of. Is the see-saw bright blue with horsey heads on?joe-90 said:If the ballcock is set too high you will get hydraulic see-sawing which often fools the poster because it overflows for a while - and then stops, then overflows - and then stops.
Well then, I shall call it, um.... Malcolmjoe-90 said:See-saw, flip-flop, stop-start, call it what you will.
Of course it would, but the cause of the overflow is the level of the water, not the surface tension forces at the surface of the water.joe-90 said:BTW are you saying that having the water level set too high will not cause the tank to overflow?
Oh it would??
