dripping overflow
26 Jun 2012
Durham
I know this topic has been raised before but can't seem to see an answer to my query! so please help...
overflow is dripping, in the tank it is the little white plastic pipe on top of the inlet pipe - hopefully image attached
how do i stop it dripping???
You could just bend the brass arm down slightly (without breaking the valve! ) this would excert more pressure on the pin.
The washer may be worn or a little bit of grit has got in it, which would require you to unscrew the round brass section and take out the washer and either clean or replace. There should be instructions with pictures for this in most DIY books
cheers terry, and do you know what the purpose of the white pipe is?
When you say the White pipe, do you mean the overflow or the little White bit on top of the valve?
The overflow is to carry away water when you the tank over fills
The White bit on top of your valve is to meet regulations on a part two valve, a part one would fill from the underside of the valve
If you pulled that off the water when filling would spray upwards, this elbow directs it down into the tank.
Bending the arm will cure your problem for the short term. As soon as water is drawn off the water will fill to the new (lower level) and the drips will return. For £6-7 fit a new ball valve assy complete, or as suggested dismantle and clean it.
