I have renovated my en-suite and fitted a new shower head and Mixer valve which is fed from a Power pump. I removed the non-return valves from the mixer valve as I had read that they weren't necessary and may reduce the pressure.
I now find that everything works fine except when I switch the shower off, after anything from 1 to 4 hours afterwards, the shower head suddenly starts dripping. This can be quite annoying when it happens in the middle of the night and I wake up thinking we have a major leak!!!
The shower head is a largish drench type head. I am thinking that there is a vacumn that prevents the water releasing from the head but after a while, this vacumn is lost and the water is released.
Could the fitting of a single check valve on the shower head fix this problem or should I refit the Mixer valve non-return valves?
Any advice appreciated.
Regards
Regards
