Yes that's possible and the BG chap may be the first to have opened it for years. Replacing it will be the next job, probably with an automatic valve but, with a stopcock in the pipe, it's no longer urgent. I can still bleed it by opening the stopcock and the manual air vent.
My biggest problem still is the boiler making a lot of banging when it starts up but not always and often not starting at all, occasionally with an F24 fault, but then starting itself fairly normally an hour or two later.
The plumber thought it may just be air in the system following his partial draining to fix the pipe and suggested turning the boiler off, opening the drain valve and bleeding the radiators to clear any airlock.
However the banging was the problem that led me to take out a maintenance contract with BG followed two days later by an F24 and no heating which led me to book a repair from them before going into contract. That "repair" was last Sunday but the BG "engineer" just looked at it, cleaned the Magna filter, pronounced the water clean and said the boiler was OK (it had started working agan) and as I was due the first boiler service on Monday, did nothig else. The second engineer never did service the boiler as he found a slightly leakiing gas valve and disconnected the boiler (for £160) before booking a repair to that for Wednesday (est £340) The third BG engineer - who seemed brighter than the others- turned up on Wednesday only to find that engineer no.2 had ordered the valve but not the seals so couldn't do it. He came back on Thursday and did repair the leaking valve and reconnected the boiler (I asked him why it hadn't simply been isolated, I'm not the sort of idiot who would try to turn it back on, and he didn't know, very much implying that no. 2 wasn't the brightest star in the BG firmament. I then had heat again after three days of fan heaters but then discovered the dripping vent valve and I'm now right back to sguare one but hundreds of pound worse off.
I'm now thinking of cutting my losses, telling BG to stuff their maintenance contract, which is still in cooling off so I had to pay for their "engineers", and getting an independent to go over the system.
