Hi folks new to the forum, any advice gladly accepted! I have just set about renovating / repairing a house I have just moved into. The front of the house and part of the side of the house had / has a damp problem.
I have identified the source of the damp as a combination of the ground being too high - it was two courses above the damp proof course at the front of the house . I have dug this out and the masonry seems to be drying out nicely. I will now pave it and install some drainage.
The problem looks to be the same along the side of the house, the ground is too high – almost level with the damp proof course due to the brick drive being too high (previous owner). Also there is a poorly installed gutter downpipe.
The problem is the drive is fairly long (and narrow so next to useless!) but is a reasonable brick finish. I am loathed to dig this up to try and lower the level of the drive as plenty of other work needs doing / paying for - but if it’s the only solution?
Can drainage sort this problem?
1) Can I install a French drain down the side of the property
2) Can I install linear drain channel down the side of the property
My concerns with a French drain are that it will have to be butted up right against the wall of the house and will be going in near the foundations - this doesn’t sound like a good idea to me?
My concern s with linear drain channel are that it will only drain surface water - will the area under the channel / drive still seep water into the side wall of the house.
Any input much appreciated!
Matt
Photos with descriptions should be on here
//www.diynot.com/network/busdriverman/albums/
Matt
