Hello all,
Can someone help with some advice for my neighbour and I? Its an ongoing saga so apologies in advice for the long story but i hope it helps.
We live in detached house with attached garages with attached driveway in front. The driveway has a drain for rain water.
This drain keeps overflowing during wet weather and the water level becomes so high that the driveway floods and water seeps under the garage door. There are also two drains at the front of each house which overflow. These are from the sinks in our downstairs loos. Theres quite an offensive smell outside too but only when it floods/is raining and theres no evidence of sewer type waste.
The drain itself is always nearly full of water since this started happening. It used to sit empty and was a chamber with small partition at the bottom and an exit going off in the direction of the road at the bottom. There is no rubbish to be felt in there and we can rod along to 3-4, before it seems to get stuck. When we put a running hosepipe on down the drain it doesnt flood even on full pelt. When we have the hosepipe and both of our sink taps on it does eventually flood slowly but takes 15-20mins or so.
We've had some professional guys with a camera come along and they can get to 8metres but no further and told me all they could see is the pipes full of water and they couldnt go any further due to the weight of the water rather than because of a blockage.
Our houses are part of 6 houses which are all close together in one local area. We think all of the gutters and driveway drains from all of the houses may drain to the same point. Today the driveway flooded again but there was no rain. We found one of our neighbours had his hosepipe down his driveway drain which was 20-30 metres away and off at more than a right angle away from our driveways. Neither he nor any of the other neighbours gets and flooding or overflowing.
My question is whether anyone knows whats likely to be causing the problem (a pipe blockage or saturated soakaway etc?)? What type of system of drainage is this likely to be? (a soakaway?)
How do we find out what the problem is in the cheapest and quickest way?
How do we fix the likely problem if anyone knows what it is?
Thanks in advance for any help as this is getting frustrating and expensive.
T
T
