driveway
11 Dec 2006
Leicester
hope im asking in the right place!
im planning on doing my own driveway, but have not much of a clue!
the driveway is going to be slabs.
so am i correct in thinking the area has to be dug 6cm down for the hardcore??
then do i put anything between the hardcore and slabs?
do i put sand in the gaps (i feel the need to "grout" as im a tiler :LOL: )
any help muchly appreciated :)
Slabs for a drive should really be on a solid bed to prevent them cracking when you drive on them
Whether you joint them or not depends on the slab you choose
I would have minimum 200mm hardcore off solid ground. Then a 50mm sand/cement bed
I don't think you will need a weed membrane, unless the joints are to be just sand
sorry this might jsut be me being thick then! so i need the hardcore on the mud then cement on top??
and the slabs will be just run of the mill ones that you can get anywhere.
