Recently had to drain my system to install some new rads.
Upstairs drained fine but i initially couldn’t get the downstairs rads to drain. I later found out from here that the downstairs rads were probably drop fed from above.
I only drained down the 2 ground floor rads that I needed to work on and left the remaining 4 which were still holding water.
The ground floor rads are fed from 10mm pipe that is buried in a concrete floor so I can’t really trace back the pipe work to see where it comes from.
Is there a way that I can find out whether or not all of the ground floor rads are drop fed? And would each rad be fed individually?
Cheers
rob
Cheers
rob
