Hi All,
Any body know how straighten an exterior door that has dropped at the lock side. The door is timber with 9 small glazed panels in the top half and 3 long vertical ply(?) panels in the bottom half. I want to raise the lock side by about 6 to 7mm.
The top rail (transom?)joints to the side rails appear good, the paint over the mid and bottom rails to side rail vertical joints are both cracked and bottom ply panels joints also appear cracked (least ways the paint is).
The timber of the door itself appears to be in good condition and the friend i'm doing the job for can't afford a new door and frame. Bottom of the door frame sides and threshold were rotten but i've replaced those.
Any help would be much appreciated.
