Drum shaft seal - Hotpoint 9515 w/m
20 Jun 2006
Oxfordshire
Please help.
My Hotpoint 9515 was making awful noises which were traced to the drum bearings.
Getting the drum assembly out was slow but relatively easy for this former engineer.
The inner, stainless steel, drum is now removed from the outer "plastic" one, and the exact cause of the ruined bearings is now very clear.
The seal runs on a bronze(?) bush. In this instance the bronze bush has developed a longitudinal split, so even a new seal is not going to keep water out of the bearings! Photo available if this helps.
Question:-
Is there a simple replacement for the bronze bush, or does one replace the entire rotating three-legged spider and shaft assembly? If so, where is it available, and at what sort of price? (I already have the new seal and bearings)
Thanks, PWat
when i worked for hp you changed the spider, bearings (kit) and fromt dum seal, this way you made sure it never leaked and not noisey.
I suggest you get new spider from same place you got bearings
Job done successfully, if somewhat slowly
The M/c is now sooo quiet in comparison with how it was!
Regards
PWat
i know this will be of no comparison, but how long did it take to do?
When i worked for hp to change bearings they allowed us....
yes i know we had all the tools, but i am just curios as to how long it took you
