Dry dash chips.
5 Apr 2010
Invernesshire
Hello. I have a wall in the garden i want to dry dash and was wondering what is the rough amount(kg) of dry dash chips required per metre squared.
Thx in advance
steve.
You should be looking to get around 4 sq metres, (approx), from a 25 kg bag, if the chip size is around 6-8mm. You would also need to put polythene sheeting or similar onto the ground, to catch the chips that fall as you dash, so you can use them again. Keep them clean.
