Hi all, I am going to attempt to dryline my garage and put a ceiling up. I need some advice...
First of all, the garage is just brick inside with the rafters showing etc, and I would like to have a gym in there eventually. I guess I put plaster boards up first on ceiling, then dry line the walls?
As there is no insualtion in the garage, should I use these plasterboards with foil backing? Can you still use plasterboard adhesive with them?
Also, one wall has electric cables in trunking coming down to the light switch. How do I dry line that wall as the trunking is obviously raised from the wall? Would I have to put battons up on the wall and screw the plasterboard into that?
I'm also not planning to plaster, I was just going to joint tape it and paint it with plasterboard sealer then a couple of coats of emulsion (I know, lazy, but I can't plaster and it's only for the garage!) How do you joint the seal between the ceiling and walls?
I've never done walls before, but have put a few ceilings up, so please forgive me for sounding useless!
