Dry lining corners
29 Nov 2008
I am currently dry lining a couple of the walls in my kitchen, how do you mask the joins and exterior corners (ie reveals etc)?? What tape/filler do I need ?
I don't want to plaster if I can avoid it !!!
You can get corner bead tape for exterior corners plus reveals. Paper tape for joints in the centre of the plasterboard. Joint filler is gyproc 12.5 kg bag should be more than enough for your job. Leave to dry fully and then sand back taking care not to tear in to paper backing on the plasterboard. Hope this helps you. :) S/ slasher
Cheers slasher,
got that lot yesterday !! thanks for the advice.
