Hi. I know there's a lot of info on dry lining out there but (typically) not quite what I'm trying to find out. Basically, on a wall that's damp (penetrating) and will stay damp due to the cavity wall insulation getting wet, we have been given this as an option: "Take off plaster, frame wall with 50x25mm treated farming fiexed to brick wall with metal vine eyes. Fix 12.5mm foil backed plasterboard"
Would the damp just penetrate the wood? And if so, what sort of time frame would it take to happen?
The other solution we've been offered is to again take off all the old plaster, but then to put up a damp proof membrane before re-plastering.
Thoughts on which is most effective??
Many thanks!
Many thanks!
