My house (typical 3-bed semi) has solid walls, and the side wall not only faces north but is only a single drive-way width away from the next house (we have shared driveways here). So it gets no sun, and is always very cold in winter.
It's never caused any problems though, but we noticed recently that the section where we hang coats in the hall was very damp, and one of the coats had got some mildew spots. There was a noticeable film of condensation on the wall, which is papered and painted. The coats have been removed, and now (a week later), no sign of damp, so I'm pretty sure it was just condensation - cold wall, lack of air circulating there, damp coats now & then, and typical tightly sealed house with people breathing, cooking etc.
We don't have a general problem with condensation in the house, and I suspect the reason we've never had trouble on this wall before is that up until now there was a radiator on it, running along under where the coats hang, but earlier this year we removed that and installed a vertical panel to one side of this area.
I plan to insulate & dry-line it with battens/polystyrene slabs/plasterboard, and I have a few questions.
1) Should I first strip off the painted paper and take the wall back to bare plaster to allow it to breathe better?
2) Should I either tack a sheet of polythene over the battens or use foil-backed plasterboard?
