Dry nose
Have you ever spent a period of time away from your home? Does it change?
Now that you mention it, I went on holiday last year to Dubai and didn't need to use my Olbas oil that much.
So, the humidity meter has finally arrived ( drumroll )
At the moment, it's showing 60% humidity 19.2 C
That's about perfect. Keep checking every few hours to see if it changes, for example when the heating has been on for a bit.
You might need to look elsewhere for the cause.
Now showing 56% with 21C.
Hmm.. what could be the cause? Does having a plant like a cactus in the room help ?
I have this gut feeling that it's something to do with the house or the building material that was used.
Lol. So this dry nose episode is only evident when you are at home?
It does not happen when you are away from home?
What do you know aggravates it?
Stay in a hotel for a few nights.
Leave the door leading to the pool open for a bit, that’ll get the humidity up.
