Drying times for new screed?
19 May 2006
Can anyone advise how long I would need to leave a 50mm screed (over concrete base) before I can carpet?
Many thanks,
Rule of thumb: 30 days per inch (25.4mm) new concrete/screed
Wow, it'll take 3 months for mine then as my screed is going to be 3 inches in depth with tiles over the top. Glad I saw this thread; came in handy for me too :). Thank you.
would the introduction of an industrial dehumidifier speed up the process and to what extent ?
could you explain how please i was led to believe that a dehumidifier would take the moisture content out of the room and therefore draw the moisture from the screed and unlike a heater not crack the floor or new plaster work could anyone explain where i am going wrong with this thought then please it would be much appreciated thanks :?: and i'm fairly new at this so be gentle
Yes, it takes 1 day per mm, so allow 50 days - or 7 weeks - for a 50mm screed to be dry enough to overlay with impermeable coverings such as vinyl and carpet.
The easiest way to speed the process is to use a product called Uniscreed. There are 3 grades:
Uniscreed Standard (a liquid admix) will cut this drying time down to 8 days.
Uniscreed Rapid (a powder admix) will cut it down to 3 days.
Uniscreed FastDry (a cement replacement) will cut it down to 1 1/2 days.
The cost goes up as the drying time comes down.
Good luck.
Adverising link has been removed.
Mod Rupert
