- Joined
- 5 Dec 2012
- Messages
- 929
- Reaction score
- 13
- Country
Hi all,
moving house in a couple of months, and i work from home as a sports massage therapist.
My new place of work is going to be my new single (detatched) garage.
I am going to put two velux windows in (each either side of the roof) The garage is NOT a flat roof.
Obviosuly, i need to insulate and board the room.
What i plan on doing is this:
- fixing timber (2 by 2's) to the wall at 600mm centres?
- putting insukation inbetween the timber frame
- plasterboarding and skimming
My main queries are with the garage door, and the insulation in the garage
I need to keep the garage door as it is, so i will be insulating the back of the garage door - there is a side door to the garage from the garden.
1. What insulation should i affix to the back of the garage door - and how do i attach it?
2. What insulation would you use inbetween the timber on the internal garage walls?
3. what insulation would you use in the roof?
4. I understand i need a bit of a ventilation inbetween the wall and the insulation - how do i achieve this?
5. In regards to the flooring, what would you do in order to achieve a decent temperature flooring - it is currently concrete. My end result is to have a laminate floor.
Edit: my source of heat will be a plug in heater
thanks for your input
Mark
Mark
