I have a 1930s house with some damp rising along 2 of the walls, nothing major apart from some flaky paint on 1 of the walls. It's 9" brick solid wall with a very small cavity of around 20mm. I have got some of the Dryrod kits off Amazon, there is an existing damp membrane that I can see along the mortar course. I suspect that since 1930 this as seriously deteriorated, can I install the dryrods along the same course? I can't go any higher and if I go a course lower I'm 1 brick away from ground level.
It looks like something has been injected into the actual bricks in the past, I can see a number of holes evenly spaced.
