Hi All,
Hopefully a very simple answer to this.
I need to Plasterboard a ceiling below a flat roof, in a newly built extension.
Currently have Insulation between the Joists & have screwed 30mm celotex under the joists & now need to fix the 12.5mm Plasterboard under the celotex.
What is the ideal Depth the screws should penetrate the joists in this situation, I was thinking 25mm?
So, 12.5 + 30 + 25 = 67.5mm
Looking around locally it seems you get either 65mm or 75mm, 65mm being very slightly under but 75mm possibly being over kill?
What would you use?
I have found you can get 70mm online if that's the ideal size?
Cheers
What would you use?
Cheers
