Since there were cold spots at the bottom of my radiators, which are about 15years old, I decided to give the system (Potterton Profile 60 with 5 rads) a dose of DS-40.I ran the system for a few weeks and it was running well and noticably quieter than before.
However, after draining the system, adding the neutraliser, and filling & draining 3 times, things have gone a bit pear shaped.
The boiler has started kettling, and now overheats, knocking out the safety thermostat a few times a day. As well as the kettling the boiler sometimes starts to make a cyclic swooshing noise.
I removed the pump, where there was some debris, and flushed the system out until the water ran crystal clear. Although the kettling is not as bad the boiler still trips out and the FE tank is a horrible brown mess again.
One other odd symptom, is that there is an occasional small leak at the drain valve (at the first radiator). The leak, no more than a tablespoon each time, is yellow.
Any advice would be appreciated.
