I've setup a few DT8M Wireless PIRs as a quick temp fix before installing some hard wired detectors. Inserted the batteries, all configured as a zone, signal strengh good, walk test working fine, set the system, moved a bit , lit up and set off intruder alarm.
However, i left the system idle for some time and came back to it later. The PIRs no longer light up when motion is detected.
I full set the system, did a song and a dance in front of it, but it didn't trigger an intruder alarm.
Whats happening, as means i could be setting the system fully, an intruder could pass the detector and no longer trigger the alarm!
Seems they've gone to sleep and not waking up without putting out the batteries and powering back on again!
