hi
new to this forum and i have had a read on the various topics but still thought i would ask
in the airing cupboard we have a header tank above the hot water heater tank(big copper tank).
the header tank looks like its got an inner tank built in,both have separate mains water feeds thru their own ballcocks.
now the problem is that the larger of the 2 tanks is leaking thru the overflow outside,its more than a drip,more like a slow trickle.
i have tied the ballcock up on the large tank and the small tank and you can still see the water rising,takes about 5 mins to raise 5mm or so,i emptied the main tank half way down and i cannot see any water leaking from the ballcock/washer area and running down the tank side on the large tank,i cannot get into the inner header tank one to check as the space is very confined and i cant get my head all the way in as its near the roof in the airing cupboard,i suspect i will have to dismantle the whole tank to remove it to check.
now all this is happening without any of the heating turned on,we have radiators fitted but never use them,we just use the gas fire as house is usually warm enough,so we only ever have the hot water on,as i said,this is happening without any heating on.
now could it be the back ballcock in the small tank is leaking somehow and filling the main tank up?
the house is an ex council house and has all the original plumbing in etc.
thanks
dave
thanks
dave
