Edit: added models of current equipment
Hey.
I''m considering something for ease but not sure if its a bad idea.
I have a largish 4 bed detached bought recently. Owners had left the country and house had a flood so was a bit of a do-up project.
They had an ASHP installed in combination with a V old Gas boiler and vented system but it was done V badly. See here for a bit more info.
ASHP = Viessmann Vitocal 300A,
Hot Water Tank = Viessmann Vitocell 300B) (2 coils, pressurised HWT)
Also have a Solar Thermal set up to feed into the Vitocell largest coil.
Vitocal 300A + controller
Vitocell 100e
Vitocell 300b
Solar System Vitosol 100f ???
Starting from scratch as all pipes and old rads ripped out.
Having UFH downstairs using panels (www.floorheater.co.uk) but cant afford it upstairs plus all the cost to get the ASHP to do the hot water or run low temp rads upstairs
I'm having a nightmare with costs of getting the system up and running. 1 quote has come in as around 10k EXCLUDING the heat destinations e.g UFH or Rads + hot and cold mains around the house. (Can do that myself).
Question:
1. Is it a bad idea to use the ASHP for UFH downstairs only, (Ideal for UFH as uses low temps + weather compensation), then use a Gas boiler to do the hot water, and standard Rads upstairs?
2. If its a bad idea anyone got any tips or advice on this: run Gas boiler which i know can mix down for UFH to low temp, but then run standard rads upstairs, do the HW + use Weather Compensation?
Thinking of a Viessmann 200 system boiler if going Gas route.
I'm not sure on the Gas system running weather comp yet needing dual temps for upstairs + downstairs. May cost a lot to run??
Any help appreciated. If any serious plumbers around i'm in staffordshire not too far from Stoke-on-Trent.
Hey.
Vitocell 100e
Vitocell 300b
Question:
