Need some advice on how to fit a dual immersion switch, I have 2 cables at the socket point, 1 is the load the other 1 is the supply, I do not have the old dual immersion switch as the electrician fitted a new single 20 AMP switch, which becomes too hot to touch after 20mins of being switched on.
After speaking to the electrician he told me that it is a 20AMP switch and should be ok, another electrician told me that I need a dual immersion switch to replace the single switch, on that note I have brought a MKK5208 dual immersion switch just like the picture above, the diagram picture is the back of the switch, I’m not really sure how to fit it, I’m assuming that the LOAD cable goes to the LOAD Live and Neutral and the SUPPLY cable goes to the SUPPLY Live & Neutral, but what do you connect to the left hand side of the switch where it says 1 – 2 & SP - COM
Any help would be much appreciated
Tom
