Sorry Securespark I meant thanks SS
I must be boring you all now, so onward !!
Current bathroom wiring.
Bathroom light switch. Supply side.
Two 2core + earth, one 3 core + earth. Cables. All three red lives connected together : three associated earths connected together.
The two, 2core+earth cables are supplying the power from existing lighting circuit and being connected are allowing supply to the next room in the chain. ( the neutral conductors are snipped and unused )
The 3core + earth, load side, has a permanent Live (the 3rd red), a yellow, being the switched live, earth, and snipped unused neutral.
The 3core + earth from pull switch supplies an existing junction box ‘x’ ( round plastic type ) at this box the Neutral single core part of lighting circuit is brought in. In terms of a cable which has been parted then reconnected inside the Junction box.
A 2core + earth cable supplies the bathroom light fitting, from this junction box ‘x’, using switched live, neutral and earth.
A 3 core + earth (N/Req ) supplies the fan. Again from the junction box ‘x’. Live, switched live (yellow), neutral. Earth is connected at junction box, but snipped and not required at fan.
There are about 2 metres separating the cabling to bathroom switch and the neutral connections to the existing junction box ‘x’.
My proposed method :- I will pull the supply to bathroom switch cables, reconnect together in new junction box A.
Pull the neutrals from box ‘x’ and reconnect in a further new junction box B.( 2metres distant from A) From this box take a link neutral to the junction box A.
From Box A take a single 2 core + earth to the 2pole FCU sited on landing, forming it’s supply live neutral and earth.
From the FCU load side, another 2 core + earth to a third junction box C, from here take 2core + earth using live and earth only re-providing supply to bathroom switch, then, also from box C 2core + earth using only neutral, link to original junction box ‘x’.
I hope this can show how a simple looking job, to a non-sparky, can become quite complex, and I wonder how many extractor fans are properly installed ( not that I am saying my ideas above are correct ) Just that a wiring schematic for the fan looks quite simple, the reality is, from what I can see in my loft, quite different.
Am not about to embark on the project without discussion ….. I have described the current situation as well as I can ……. This was the contractors installation about 5 years ago.
Funnily enough the main contractor was a PLUMBER … a sparks did the electrics. I must say all has worked perfectly until now.
Sorry folks.
P.
