I have a portable air conditioner which has an exhaust pipe to vent the hot air outside. The problem with this is that a window is needed to be open which causes the air conditioner to fight it's self, exspecialy in the summer months, as warm air blows back into the room.
So I was thinking, could the pipe be put through the ceiling and into the loft space and just release the hot air there?
This will have the advantage of no window open, so less noise and a lower electricity bill as the air con unit will have to operate less with no hot air coming back into the room.
The plan is to simply make a 5" diameter hole in the plasterboard of the ceiling and feed the pipe into the loft space, I cant think of any dangers of doing this, the roof is not felted so im asuming the hot air will work it's way out through the roof. The roof does however have some sort of strong black sheeting across the inside.
Can anyone see a problem with doing this, any potential hazards? I cant see there being a fire risk as it is just hot air but I thought I would ask people that are more in the know than I am.
Thanks for any advice.
