https://www.screwfix.com/p/thomas-dudley-ltd-turbo-88-siphon-9/8461f
I have the 9L version installed in two toilets here, of that model and at first I could not get the reduced flush to work reliably. Both were installed new, to replace some older flush units. Enquiring with Dudley they suggested the fill valve was set too fill to too high a level. It would sometimes flush at reduced sometimes not, by holding the flush handle down. A workaround was to press the handle twice and hold it down at the second press, where it would work reduced every time.
Reducing the fill level helped a little, but didn't completely fix it, besides reducing the level reduced the effectiveness of the full flush - meaning it would sometimes requires several full flushes to clear the bowl. Both units have the same issue.
Has anyone found a fix, or found that their 88 works as designed on the reduced flush please?
