Can you help with this wiring problem that is not covered in the wiki.
I have a double switch in the hall that should power the hall lights and an outside light. The outside light has never worked, but the hall lights have. The wiring at the switch has (on the working side), a live to L and a yellow wire with red sleeve to L1. The non working side (that is for the outside light) is wired the same. Neutrals are joined together with a terminal block.
There is no power at the L terminal on the non working side, and the wires are joined at the outside light as follows: Yellow with sleeve to black and red to red. The neutral is just into a terminal block and not joined to anything.
I have taken power from the live terminal at the switch to the non live terminal and this gets the power to the light but it is not working. What is wrong.
