Hello
I am considering painting my two garage doors, one metal and one wood, with Dulux Weathershield Exterior Satin and wondered if anyone having used this paint before could offer some advice on any possible pros and cons?
From what I have seen already it seems very easy to apply, covers well and dries quickly.
However it seems very difficult to remove, which is probably why it gives such good protection. If you use a heat gun on the paint it simply melts into a sticky goo and it's tough so sanding it off would be very slow.
So if you use Weathershield and want to redecorate again in the future, would the only option be to paint over the existing surfaces using weathershield again?
Thanks for any advice
Robin
Robin
