What's the correct part(s)/method to make mains water connection on my new Duravit toilet cistern? The connector sticking out of the bottom of the cistern has an outside diameter of 16.5mm (outer diamter of threads) this seems to be a bit smaller than the other toilet in my house. I am guessing that this is some sort of european thingy. The inside of the cistern has a load of Gerberit stuff inside with a shiny flexible pipe running from the gerberit stuff. It's the end of the shiny flexible pipe that has the funny connector. Hopefully there is a standard connector I can buy for this to get me across to 15mm pipes?
