Duravit Vero W/C!!!!!
11 Sep 2007
Ok guys, anyone fitted one of these before?
Supplied by Bathzone, instructions are worse than useless.
Trying to work out how to connect the inlet valve to pipework. Its a really odd fitting that they supply, which has a chrome nut, rubber washer, metal rubber and what looks like a small olive, but has a split in it.
10mm copper does fit nicely and I can only assume that the fitting supplied is basically a compression fitting, which seems pretty odd for an inlet valve..........
Any help would be appreciated.
Cheers
Ring the manufacturers! You may feel like a d**k but chances are you'll never meet them....
If the olive has a split, normally 45degs then it's for plastic pipes
ive done some duravit stuff, cant remember the model name of it tho. it was a pan, plastic cistern and then a china cover to go over the cistern. we had to chase cold feed up the wall with a male iron turned out just above the cistern, make the braided hose onto the male iron then put the cover on.
Had a new Duravit cistern and WC recently. It kept overflowing (into the bowl) and it took my plumber ages to find a tiny piece of grit in the diaphragm - sort of embedded there, not loose. He used sand paper or similar to fettle it. Hope yours is OK.
