DVR and Cameras on Different Phases
7 Oct 2007
Yorkshire
Hi There,
When installing a CCTV system where the cameras are SELV, is it acceptable to install the power supply unit on a different phase to the DVR?
As the cameras run on smoothed DC and is separated then it shouldn't matter.
Hi There,
A fairly common occurence on commercial/industrial jobs if wanting to keep power cable runs to a minimum.
I can't say i have done as suggested, by a mate used to do it, and they always used to run all cameras from the same supply to avoid problems. even if that means running 4mm's for sockets they would do it.
I have also heard of a device called a humbug its designed for cctv use to reove the "hum" of different earths
There are 2 PSU's (1 Per Floor, 8 Way with battery backup)
The DVR and psu's are on a different phase, the DVR is at one end of the building and the cameras are central. It was done like this to minimise power cable runs.
Thanks for mentioning that humbug, it may come in useful as I have one camera that is "wobbling"
yep, the humbug's are the way 4ward!
iv used them many of times on system's that use more than 1 phase!
