I'm planning to build a small boundary wall in my garden next spring. Probably around 5 or 6 courses of bricks high, 2 skins.
Often one of the first things to go in garden walls is often the bottom couple of layers of brick - they blow, presumably from damp and freeze/thaw. Someone suggested I should use engineeering bricks for the bottom two courses. Any thoughts? I've got 3 concerns:
1) It seems like a good idea, but when I walk down the street I don't see anyone else with engineering bricks at the bottom of their wall (unless they have managed to get them identical to the facing bricks used on the rest of the wall). How come professional builders don't do this? Why aren't engineering bricks used below the DPC on houses?
2) Would it look naff? Engineering bricks are generally advertised as not being suitable as facing bricks
3) Different mortar mix for bonding engineering bricks?
Cheers!
Cheers!
