- Joined
- 19 Jan 2008
- Messages
- 15
- Reaction score
- 0
- Country
Hi all i'm after a bit of help. I'm starting to build a conservatory and was just deciding the best way of doing things. I have a huge concrete slab on 80% of where the conservatory is going to be going. My qustion is, is it ok to build the dwarf wall on the concrete slab if so what min depth would the slab have to be it's about 400mm deep. the remainder would have footing like normal. Also is it a problem if the slab is running out over 3m it drops 100-150mm can this be built up when building the drawf wall
Many Thanks for your help
Dan
Dan
