Hi all
I went to use my mum's Dyson the other day.
I pressed the boost button and after a few seconds the vac cut out and the blue LED flashed 10 times.
Today, even though it was on charge overnight, now it only runs for about 5 seconds and then the LED flashes again.
A few days ago it seemed to be fine.
I stripped it down and cleaned all of the cyclones.
I did recently move the docking station. Whilst doing so, I noticed that the charger flex hadn't been run behind the docking station. Using a pair of pliers, I pulled the charging lead out (by the pin).
Initially, I wondered if I might have damaged the pin but when you put the vac in the docking station the solid blue light shows until the charger is turned off. I tested the charging pin, it shows 28v.
Would the blue LED light up if the charger was faulty?
In the event that the charger is OK, I will order a new battery.
