the water failed to drain after a main wash.i did a small bit of maintenance -cleaned the debris coin hole. cleaned washers-then drained the machine through the debris hole .i tried to use the machine again after a couple oif hours but it came up error14 (flooded ).what could have been the initial cause?what to do next?can i fix it without calling an engineer?thanks.
