earth bonding kitchen pipes
1 Mar 2005
Stirlingshire
when carrying out earth bonding to copper pipes under the kitchen sink would bonding back to the earth connection in a close socket be sufficient?
Unless you ahve a bath or shower in your kitchen you do not need to bond anything.
Please use search and see other posts on this subject (yawn)
TTC
You can if you want to, but supplementary bonding in kitchens is no longer a requirement. However if you have a gas boiler, all the metal pipes that go into it should be bonded together.
I take it you were wondering if it should go back to the main earthing terminal at the meter or consumer unit? No, that is only needed for main bonding to the incoming water main and gas main.
The question is a tad ambiguous
There is no requirement for supplementary bonding in a kitchen, however if your stop cock is under the sink there is a requirement to bond the incoming copper pipe in 10mm2 back to main earthing terminal.
