Hi just bought a property the only bonding is from consumer unit to cold water pipe
Is this ok or does gas meter need doing ?
Are you sure that it's not from the water pipe to the CU?Hi just bought a property the only bonding is from consumer unit to cold water pipe
Does the gas service present an extraneous-conductive-part?Is this ok or does gas meter need doing ?
Ask the person who is installing your consumer unit.
And are you sure that it's an equipotential bonding connection and not a non-compliant TT earth?
It's literally a clip on the nearest cold pipe through wall in to cuAsk the person who is installing your consumer unit.
Gas safe relaxed there law on bonding pipes below boilers
Is that wrong? What about vice-versa?It seams your last house had the main bonding connected to your suplimentry bonding
Doesn't it depend on where the meter is?Gas safe advise you have the main bonding to the gas meter before any elbows
Do you think they may be following the Wiring Regulations?The Electricity council say where reasonable possible.
The water never needs bonding; it is metal pipes which may be a problem.The water sometimes dont need main bonding, i.e plastic incoming
I didn't know that but as above.Gas safe relaxed there law on bonding pipes below boilers , however some engineers do them, which isnt a problem.
That doesn't apply to main bonding as above.If you have RCD's on your fuse box then you dont need to bond your pipes
Nor, it seems, do you see a reason to explain to him how to check if he has e-c-ps in the bathroom, because if he hasn't then applying supplementary bonding will make things more dangerous.Main bonding is important for safety. Installing it is not notifiable work, and you are permitted to do it yourself. I see no reason to discourage you.
That's really just a word game, isn't it? If one had a TT installation, with an earth electrode, and the DNO came along and introduced a TN supply cable into the property, would you then regard the DNO's 'earth' as an extraneous-conductive-part?The earth electrode is only required with a TT earth system with a TN system you can't have an earth electrode. This does not mean you can't have a rod stuck into the ground it just means that rod is given another name it becomes an extraneous-conductive-part.
