I am in the middle of having my kitchen refitted. The sink unit had to be moved slightly to where it was previously, therefore the pipes had to me moved. The 10mm earth cable was cut to fit the pipes in the old location. Is it ok to fix a earth terminal block to the wall to extend the 10mm earth cable to the new location of the pipes or does it have to be one unbroken connection between the cold water inlet and the Consumer Unit?
Thank you for any help
