I tried to post this once, so if it's a repeat please accept my apologies.
I've just had to do some major rewiring in the house, to create two new ring mains. this involved disconnecting and continuity checking each and every plug socket, including the cooker. Thank God the cooker was on its own radial and so in effect all I had to do when the work was done is connect it back up. However, although all the other wiring is fine, when I recoonected up the cooker, it kept tripping the MCB or RCD. I systematically checked that I had 240v to the cooker socker and plug. Then I had 240v going into the cooker (both with cooker disconnected). But when I reconnect then cooker... TRIP!!!
The MCB is 40A. So the question is:-
Is the MCB big enough? I don't want to put a bigger one in and find that something starts to over heat.
Also I read that the cooker itself could be at fault. dust / moisture.
Could the Socket also be at fault?
