Hope you can help as I'd like some clarification before I go ahead with the following.
I'm installing a new aerial socket in our bedroom that will be connected to the aerial and sky box downstairs via a small 2 channel ampifier/splitter in the loft. I'm fitting the socket using a flush mounted metal back box and then chasing out the wall up to the ceiling to hold some oval conduit, inside which the coax cable will run. The faceplate of the socket will be metal to match the other sockets in the room.
I need some advice as to whether the faceplate and back box (both metal) should be earthed in any way. My friend has told me that it doesn't need it but then why would the faceplate have an earth terminal? If indeed it does need earthing what is the best way to do this as it won't run near any of the main power/lighting circuits in the house.
