Hi all
Just some advice needed. Recently had fuse box updated in my 1980s purpose built flat. I have just bought some metal light switches to change over, but on removing the old plastic ones with metal screws, they are just red wires (L1, L2 and common) going up a metal pipe (attached to metal back box). No other colours. Also in the ceiling rose, there are just red and black wires, no earth wire. At the fuse box, there are loads of metal pipes passing through the fuse box.
On changing the fuse box, the electrician tested it and ticked the continuity check box on the certificate. He also recorded 0.87 for the maximum measured earth fault loop for the lighting circuit.
Does this mean the lighting system is earthed via the metal pipes and is sound? If so, would I simply require an small flex of earth wire to attach to a terminal on the metal back box and the back of the metal light switch plate?
