I've been replacing some terrible crumbling rubber cable in the upstairs lighting circuit of my new (to me!) house. I didn't mean to, but on replacing a broken light switch found this appalling wiring - odd because all other wiring in the house is more modern pvc (ring main is white pvc and downstairs lighting 1.5mm grey pvc).
Anyway, I notice that the conduit running down the walls to the switches is metal with no obvious earth - well, there wouldn't be, it's old two-core cable.
The thing is if I replace the backing box with the new ones that have an earth connection point and the conduit is in contact with the box, is that sufficient? And I assume I have to make an earth connection between the earth connection point in the switch and the connection point in the box (fiddly)
